I’m encountering a specific error while trying to build Promtail with Journal support using the command: go build --tags=promtail_journal_enabled ./clients/cmd/promtail . The error message I’m facing is as follows:
../../../../pkg/mod/k8s.io/client-go@v0.21.0/rest/request.go:42:2: no required module provides package k8s.io/apimachinery/pkg/util/clock; to add it:
go get k8s.io/apimachinery/pkg/util/clock
@usman.ahmad
Thank you!
@tonyswumac any suggestions here if possible?
Just tried to build it myself, seems to be working.
OS version (running from Vagrant):
[root@node0 loki]# cat /etc/*release
Fedora release 36 (Thirty Six)
NAME="Fedora Linux"
VERSION="36 (Thirty Six)"
ID=fedora
VERSION_ID=36
VERSION_CODENAME=""
PLATFORM_ID="platform:f36"
PRETTY_NAME="Fedora Linux 36 (Thirty Six)"
ANSI_COLOR="0;38;2;60;110;180"
LOGO=fedora-logo-icon
CPE_NAME="cpe:/o:fedoraproject:fedora:36"
HOME_URL="https://fedoraproject.org/"
DOCUMENTATION_URL="https://docs.fedoraproject.org/en-US/fedora/f36/system-administrators-guide/"
SUPPORT_URL="https://ask.fedoraproject.org/"
BUG_REPORT_URL="https://bugzilla.redhat.com/"
REDHAT_BUGZILLA_PRODUCT="Fedora"
REDHAT_BUGZILLA_PRODUCT_VERSION=36
REDHAT_SUPPORT_PRODUCT="Fedora"
REDHAT_SUPPORT_PRODUCT_VERSION=36
PRIVACY_POLICY_URL="https://fedoraproject.org/wiki/Legal:PrivacyPolicy"
SUPPORT_END=2023-05-16
Go version:
[root@node0 loki]# go version
go version go1.19.8 linux/amd64
Install dependencies and build command:
[root@node0 loki]# yum install -y systemd-devel
Last metadata expiration check: 0:03:08 ago on Thu 16 Nov 2023 04:51:52 PM UTC.
Dependencies resolved.
Package Architecture Version Repository Size
Installing:
systemd-devel x86_64 250.10-2.fc36 updates 446 k
Transaction Summary
Install 1 Package
Total download size: 446 k
Installed size: 448 k
Downloading Packages:
systemd-devel-250.10-2.fc36.x86_64.rpm 776 kB/s | 446 kB 00:00
Total 491 kB/s | 446 kB 00:00
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
Preparing : 1/1
Installing : systemd-devel-250.10-2.fc36.x86_64 1/1
Running scriptlet: systemd-devel-250.10-2.fc36.x86_64 1/1
Verifying : systemd-devel-250.10-2.fc36.x86_64 1/1
Installed:
Complete!
[root@node0 loki]#
[root@node0 loki]# go build --tags=promtail_journal_enabled ./clients/cmd/promtail
Result:
[root@node0 loki]# ./promtail --version
promtail, version (branch: , revision: 258a8b31080d919278064e56a121e744973806a5)
build user:
build date:
go version: go1.19.8
platform: linux/amd64
tags: promtail_journal_enabled
system
Closed
November 15, 2024, 6:53pm
4
