11.4.0-79146 - What are you trying to achieve?
Renaming the time series field - How are you trying to achieve it?
Using Transformations
The regex for date is - /^(\d{2}/\d{2}/\d{4}/s\d{2}:\d{2}:\d{2})$/
What happened?
The field is not getting renamed to ‘Percentage’ -
The field should get renamed to ‘Percentage’ -
“transformations”: [
“id”: “formatTime”,
“options”: {
“outputFormat”: “MM/DD/yyyy HH:mm:ss”,
“timeField”: “Time”,
“timezone”: “browser”,
“useTimezone”: true
“id”: “renameByRegex”,
“options”: {
“regex”: “/^(\d{2}\/\d{2}\/\d{4}/s\d{2}:\d{2}:\d{2})$/”,
“renamePattern”: “Percentage”
“id”: “merge”,
“options”: {}
“id”: “transpose”,
“options”: {}
“id”: “formatString”,
“options”: {
“outputFormat”: “Substring”,
“stringField”: “Field”,
“substringStart”: 7
“id”: “organize”,
“options”: {
“excludeByName”: {},
“includeByName”: {},
“indexByName”: {},
“renameByName”: {
“11/25/2024 14:48:26”: “Percentage”
“id”: “sortBy”,
“options”: {
“fields”: {},
“sort”: [
“desc”: true,
“field”: “Percentage”
No errors
- Did you follow any online instructions? If so, what is the URL?
- Didn’t follow any specific documentation.
