Hello.
I use Grafana with InfluxDB for project monitoring. Can you please tell me if it is possible to delete a project from the database using Grafana? Or does it have to be done directly from the DB console?
Grafana generally only performs read-only operations on DBs. You’ll have to use the influx CLI or the web UI
