Hi Team,
I’m new to the regular expression. I tried to extract a value from the HTML response, But every time it shows null.
The extraction code
From the response
If I use resURL[1] it throws an error.
Guide me how to extract the value ‘89’, from the response.
Hi @Gerard, the result of an http.get
is an object not just the string value of the response body. To get the response body you need to access the body
attribute of the response object - in your case searchRes.body
You actually do this in the second line of the check, the one that starts with Verify
Hi, @mstoykov thanks for the quick reply. The regex works for me, but it finds only the first match. There are multiple matches available for the mentioned regex. How to handle it.
