hello everybody,
Can we do a range aggregations on Elasticsearch datasource ?
like the below:
Yes, using filter aggregation it would be possible
really I couldn’t get it to work!
this is the kibana request: (note that kibana aggregate ranges on a scripted field)
"size": 0,
"aggs": {
"2": {
"range": {
"script": {
"inline": "!doc['End_epoch'].empty ? ((doc['End_epoch'].value - doc['epoch'].value )) : ''",
"lang": "painless"
"ranges": [
"from": 0,
"to": 20
"from": 21,
"to": 60
"from": 61
"keyed": true
"version": true,
"query": {
"bool": {
"must": [
"query_string": {
"query": "*",
"analyze_wildcard": true
"exists": {
"field": "End_Time"
"$state": {
"store": "appState"
"range": {
"timestamp": {
"gte": 1500721947332,
"lte": 1500725547333,
"format": "epoch_millis"
"must_not": []
"_source": {
"excludes": []
"highlight": {
"pre_tags": [
"@kibana-highlighted-field@"
"post_tags": [
"@/kibana-highlighted-field@"
"fields": {
"highlight_query": {
"bool": {
"must": [
"query_string": {
"query": "*",
"analyze_wildcard": true,
"all_fields": true
"match_phrase": {
"SMSC": {
"query": "Etisalat_Dir"
"exists": {
"field": "End_Time"
"$state": {
"store": "appState"
"range": {
"timestamp": {
"must_not": []
"fragment_size": 2147483647
Kibana response:
"took": 1657,
"timed_out": false,
"_shards": {
"total": 10,
"successful": 10,
"failed": 0
"hits": {
"total": 1801,
"max_score": 0,
"hits": []
"aggregations": {
"2": {
"buckets": {
"0.0-20.0": {
"from": 0,
"to": 20,
"doc_count": 1542
"21.0-60.0": {
"from": 21,
"to": 60,
"doc_count": 161
"61.0-*": {
"from": 61,
"doc_count": 91
"status": 200
How could we do the same with grafana ?
I have the exact same use case. Were you able to achieve this with grafana?
Open a feature request of support for range aggregations: https://www.elastic.co/guide/en/elasticsearch/reference/current/search-aggregations-bucket-range-aggregation.html
