Hi Community ,
Have a small question about the http.batch
method.
In my test suites, I have to prepare unique data in the DB (setup
) before the actual run, and in the end to delete this data (teardown
) from the DB.
I’m using http.batch
in both setup
and teardown
because I found that very quick and efficient (for loop taking too much time).
But now I’m concerned with its efficiency, when I will run with 1000/10000/… unique data the http.batch
will “kill” the DB API.
I tested 100 requests with http.batch
and saw (in the back-end API) that it doesn’t send simultaneously all the 100 at once - which is good!
Questions:
- Am I doing right with this method of the
setup/teardown/http.batch
? - Does the
http.batch
has kind of a threshold for simultaneous requests (if I put a million requests in it, will it send a million at once)?
