Proxy Pass - nginx - domain - origin not allowed
I’m trying to setup a proxy pass with nginx to point a subdomain to my grafana server instance.
Currently got the following nginx config and part of the grafana.ini config below.
This points me to the grafana server as expected and I can login. When I go to view a dashboard I get error origin not allowed.
How do I fix this?
server {
        listen 80;
        server_name grafana.DOMAIN.co.uk;
        location / {
                proxy_pass      http://localhost:3000/;
[server]
# Protocol (http, https, h2, socket)
;protocol = http
# The ip address to bind to, empty will bind to all interfaces
;http_addr =
# The http port  to use
;http_port = 3000
# The public facing domain name used to access grafana from a browser
;domain = grafana.DOMAIN.co.uk
# Redirect to correct domain if host header does not match domain
# Prevents DNS rebinding attacks
;enforce_domain = false
# The full public facing url you use in browser, used for redirects and emails
# If you use reverse proxy and sub path specify full url (with sub path)
;root_url = %(protocol)s://%(domain)s:%(http_port)s/
# Serve Grafana from subpath specified in `root_url` setting. By default it is set to `false` for compatibility reasons.
;serve_from_sub_path = false
Fixed - had to add the following to the nginx config
proxy_set_header Host grafana.DOMAIN.co.uk;
