I’ve been trying to configure promtail to correctly display multiline errors as a single one but i can’t seem to get it to work properly.
I am using a basic C# API project.
Here is a complete single-line log generated in my json log file that contains the \n that i would like to be considered as a single log :
{"@t":"2024-11-26T08:34:59.0688983Z","@mt":"Connection id \"{ConnectionId}\", Request id \"{TraceIdentifier}\": An unhandled exception was thrown by the application.","@l":"Error","@x":"System.InvalidOperationException: Randomly generated exception for testing.\n at ErpOrchestrator.Controllers.WeatherForecastController.Get() in /src/ErpOrchestrator/Controllers/WeatherForecastController.cs:line 34\n at lambda_method4(Closure, Object)\n at Microsoft.AspNetCore.Mvc.Infrastructure.ActionMethodExecutor.AwaitableObjectResultExecutor.Execute(ActionContext actionContext, IActionResultTypeMapper mapper, ObjectMethodExecutor executor, Object controller, Object[] arguments)\n at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.<InvokeActionMethodAsync>g__Awaited|12_0(ControllerActionInvoker invoker, ValueTask`1 actionResultValueTask)\n at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.<InvokeNextActionFilterAsync>g__Awaited|10_0(ControllerActionInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)\n at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Rethrow(ActionExecutedContextSealed context)\n at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)\n at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeInnerFilterAsync()\n--- End of stack trace from previous location ---\n at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeFilterPipelineAsync>g__Awaited|20_0(ResourceInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)\n at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeAsync>g__Logged|17_1(ResourceInvoker invoker)\n at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeAsync>g__Logged|17_1(ResourceInvoker invoker)\n at Microsoft.AspNetCore.Routing.EndpointMiddleware.<Invoke>g__AwaitRequestTask|7_0(Endpoint endpoint, Task requestTask, ILogger logger)\n at Microsoft.AspNetCore.Authorization.AuthorizationMiddleware.Invoke(HttpContext context)\n at Microsoft.AspNetCore.Authentication.AuthenticationMiddleware.Invoke(HttpContext context)\n at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.Http.HttpProtocol.ProcessRequests[TContext](IHttpApplication`1 application)","@tr":"70595badb948bbc0eee71b18f663ca06","@sp":"38e7e7cf75458783","ConnectionId":"0HN8D7UJV6FII","TraceIdentifier":"0HN8D7UJV6FII:00000003","EventId":{"Id":13,"Name":"ApplicationError"},"SourceContext":"Microsoft.AspNetCore.Server.Kestrel","RequestId":"0HN8D7UJV6FII:00000003","RequestPath":"/weatherforecast","ExceptionDetail":{"Type":"System.InvalidOperationException","HResult":-2146233079,"Message":"Randomly generated exception for testing.","Source":"ErpOrchestrator","StackTrace":" at ErpOrchestrator.Controllers.WeatherForecastController.Get() in /src/ErpOrchestrator/Controllers/WeatherForecastController.cs:line 34\n at lambda_method4(Closure, Object)\n at Microsoft.AspNetCore.Mvc.Infrastructure.ActionMethodExecutor.AwaitableObjectResultExecutor.Execute(ActionContext actionContext, IActionResultTypeMapper mapper, ObjectMethodExecutor executor, Object controller, Object[] arguments)\n at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.<InvokeActionMethodAsync>g__Awaited|12_0(ControllerActionInvoker invoker, ValueTask`1 actionResultValueTask)\n at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.<InvokeNextActionFilterAsync>g__Awaited|10_0(ControllerActionInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)\n at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Rethrow(ActionExecutedContextSealed context)\n at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)\n at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeInnerFilterAsync()\n--- End of stack trace from previous location ---\n at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeFilterPipelineAsync>g__Awaited|20_0(ResourceInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)\n at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeAsync>g__Logged|17_1(ResourceInvoker invoker)\n at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeAsync>g__Logged|17_1(ResourceInvoker invoker)\n at Microsoft.AspNetCore.Routing.EndpointMiddleware.<Invoke>g__AwaitRequestTask|7_0(Endpoint endpoint, Task requestTask, ILogger logger)\n at Microsoft.AspNetCore.Authorization.AuthorizationMiddleware.Invoke(HttpContext context)\n at Microsoft.AspNetCore.Authentication.AuthenticationMiddleware.Invoke(HttpContext context)\n at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.Http.HttpProtocol.ProcessRequests[TContext](IHttpApplication`1 application)","TargetSite":"Void MoveNext()"}}
The YAML ConfigMap as follows:
apiVersion: v1
kind: ConfigMap
metadata:
namespace: monitoring
labels:
app: promtail
data:
config.yaml: |
server:
http_listen_port: 3101
positions:
filename: /var/log/positions.yaml
clients:
- url: http://loki-gateway.monitoring.svc.cluster.local/loki/api/v1/push
tenant_id: erp-orchestrator
scrape_configs:
- job_name: erporchestrator-logs
kubernetes_sd_configs:
- role: pod
relabel_configs:
- source_labels: [__meta_kubernetes_pod_label_app]
target_label: job
replacement: erporchestrator-logs
target_label: pod_name
- source_labels: [__meta_kubernetes_namespace]
target_label: __namespace__
replacement: prod
- source_labels: [__meta_kubernetes_pod_name]
target_label: __path__
replacement: /app/logs/application_logs*.json
pipeline_stages:
- multiline:
firstline: '^{"@t"'
- replace:
expression: '(\n|\r|\r\n)'
replacement: ' '
- json:
expressions:
timestamp: '"@t"'
message: '"@mt"'
level: '"@l"'
exception: '"@x"'
stack_trace: '"@x"'
This config is correctly applied to my promtail pod and i can see the logs generated in grafana through loki source :
But as you can see they are all in multiple lines.
The log file looks something like this :
I would like the \n in the stack trace to be correctly handled as beeing part of a single log. I’ve tried to do a replace stage in the pipeline but didnt seem to help.
The configuration file is correctly applied to the pod :
Cheers for any help !
