Promtail - log file does not match glob - but it does?
Platform: linux/amd64
Promtail: 2.3.0
I’m not seeing what I’m doing wrong here.
I have a process only writing once a day to a log file. It can happen that the log file doesn’t exist at the time that promtail started. When the log file appears, promtail does not want to tail it claiming that “new file does not match glob”
Relevant config:
scrape_configs:
- job_name: prometheus
  static_configs:
  - labels:
      job: prometheus_exporters
      __path__: /opt/prometheus/log/*exporter*log
  - labels:
      job: prometheus
      __path__: /opt/prometheus/log/prometheus.log
  - labels:
      job: prometheus_backup
      __path__: /opt/prometheus/log/prometheus_backup.log
When promtail starts with log file absent
level=debug ts=2021-09-09T11:00:34.865406137Z caller=filetarget.go:197 msg="no files matched requested path, nothing will be tailed" path=/opt/prometheus/log/prometheus_backup.log
level=info ts=2021-09-09T11:00:34.865461662Z caller=filetargetmanager.go:271 msg="Removing target" key="{job=\"prometheus_backup\"}"
level=info ts=2021-09-09T11:00:34.865584982Z caller=filetarget.go:151 msg="filetarget: watcher closed, tailer stopped, positions saved" path=/opt/prometheus/log/prometheus_backup.log
When I force creation of the log file, I see this appearing:
level=debug ts=2021-09-09T11:12:00.205331105Z caller=filetarget.go:168 msg="new file does not match glob" filename=/opt/prometheus/log/prometheus_backup.log
level=debug ts=2021-09-09T11:12:00.206098947Z caller=filetarget.go:168 msg="new file does not match glob" filename=/opt/prometheus/log/prometheus_backup.log
Checking by copy pasting path from log message
-rw-rw-r-- 1 dwpmetrc dwpmetrc 0 Sep 9 13:15 /opt/prometheus/log/prometheus_backup.log
What am I overlooking?
Hhmm, interesting.
Your scrape configs don’t appear right. You’re missing static_configs; it should look like this:
scrape_configs:
  static_configs:
    - targets:
        - localhost
      labels:
Relevant docs: Configuration | Grafana Labs
I made an error when copy-pasting - original post corrected
OK - so the debug message just compares any new file against the existing file targets. After adding my own debug message in loki/clients/pkg/promtail/targets/file/filetarget.go and adding a dodo.log to my directory:
level=debug ts=2021-09-15T12:35:33.819640489Z caller=filetarget.go:167 msg=WHY error=null match=false target.path=/opt/prometheus/log/prometheus_backup.log filename=/opt/prometheus/log/dodo.log
level=debug ts=2021-09-15T12:35:33.819857511Z caller=filetarget.go:169 msg="new file does not match glob" filename=/opt/prometheus/log/dodo.log
level=debug ts=2021-09-15T12:35:33.819875777Z caller=filetarget.go:167 msg=WHY error=null match=false target.path=/opt/prometheus/log/prometheus.log filename=/opt/prometheus/log/dodo.log
level=debug ts=2021-09-15T12:35:33.819939117Z caller=filetarget.go:169 msg="new file does not match glob" filename=/opt/prometheus/log/dodo.log
However it seems that prometheus does not check if a filetarget which wasn’t present at its launch, appears later. It just removes that filetarget at launch
level=debug ts=2021-09-15T12:38:31.88237282Z caller=filetarget.go:198 msg="no files matched requested path, nothing will be tailed" path=/opt/prometheus/log/prometheus_backup.log
level=info ts=2021-09-15T12:38:31.882478211Z caller=filetargetmanager.go:271 msg="Removing target" key="{job=\"prometheus_backup\"}"
Is there any way to keep filetargets not existing at launch and make promtail tail them when they do appear?
