I want to add loki to my existing grafana but I need a way to ship the logs into another source as well, is there a way to do it? (using promtail)
To be more specific, I need to send the logs using UDP, like syslog.
Hi @dror1212
We support syslog in Promtail: https://grafana.com/docs/loki/latest/clients/promtail/configuration/#syslog
And there is an example configuration you could try:
You didn’t understand my question, I know promtail can collect logs using syslog, but I want to use syslog to ship the logs to other targets using UDP, not to loki. maybe there is a feature in loki that can pass the data to other sources?
