Promtail: “error sending batch, will retry” status=-1 context deadline exceeded”
I have a promtail client sending logs to a remote server.
My promtail config
server:
  http_listen_port: 9080
  grpc_listen_port: 0
positions:
  filename: /tmp/positions.yaml
clients:
  - url: http://<remote server>:3100/loki/api/v1/push
scrape_configs:
- job_name: system
  static_configs:
  - targets:
      - localhost
    labels:
      job: varlogs
      instance: <local server>
      __path__: /var/log/*.log
when I have my iptables configured like
Chain INPUT (policy DROP)
Chain OUTPUT (policy ACCEPT)
I get the error
msg="error sending batch, will retry" status=-1 tenant= error="Post \"http://<remote server>:3100/loki/api/v1/push\": context deadline exceeded"
When I change it to
Chain INPUT (policy ACCEPT)
it works.
Which ports needs to be configured in iptables. It seems that allowing outgoing traffic is not enough.
Thanks in advance!!
Anyone can help with configuring IP tables correctly?
Many thanks!!
