I’ve used the --dry-run switch to test my scrape job for serilog compact logs, and it works as expected calling on my term (cat sample.log | promtail --config.file promtail.yaml --stdin --dry-run --inspect --client.url http://127.0.0.1:3100/loki/api/v1/pus), but when I apply this configuration to the promtail deployment it did not accept the configuration.
The kubernetes cluster where the promtail is deployed is configured with the switch -print-config-stderr, bellow is the output from one pod, it finishes with an error and stay on crash loopback.
# Loki Config
# (version=, branch=, revision=)
server:
http_listen_address: ""
http_listen_port: 3101
http_listen_conn_limit: 0
grpc_listen_address: ""
grpc_listen_port: 9095
grpc_listen_conn_limit: 0
http_tls_config:
cert_file: ""
key_file: ""
client_auth_type: ""
client_ca_file: ""
grpc_tls_config:
cert_file: ""
key_file: ""
client_ca_file: ""
register_instrumentation: true
graceful_shutdown_timeout: 30s
http_server_read_timeout: 30s
http_server_write_timeout: 30s
http_server_idle_timeout: 2m0s
grpc_server_max_recv_msg_size: 4194304
grpc_server_max_send_msg_size: 4194304
grpc_server_max_concurrent_streams: 100
grpc_server_max_connection_idle: 2562047h47m16.854775807s
grpc_server_max_connection_age: 2562047h47m16.854775807s
grpc_server_max_connection_age_grace: 2562047h47m16.854775807s
grpc_server_keepalive_time: 2h0m0s
grpc_server_keepalive_timeout: 20s
grpc_server_min_time_between_pings: 5m0s
grpc_server_ping_without_stream_allowed: false
log_format: logfmt
log_level: error
log_source_ips_enabled: false
log_source_ips_header: ""
log_source_ips_regex: ""
http_path_prefix: ""
external_url: ""
health_check_target: null
disable: false
client:
url: http://172.16.3.22:31000/loki/api/v1/push
batchwait: 1s
batchsize: 1048576
follow_redirects: false
backoff_config:
min_period: 500ms
max_period: 5m0s
max_retries: 10
timeout: 10s
tenant_id: ""
positions:
sync_period: 10s
filename: /run/promtail/positions.yaml
ignore_invalid_yaml: false
scrape_configs:
- job_name: serilog
pipeline_stages:
- cri: {}
- json:
expressions:
exceptionType: ExceptionDetail.InnerException.Source
level: '"@l"'
requestPath: RequestPath
time: '"@t"'
- labels:
exceptionType: null
level: null
requestPath: null
- timestamp:
format: RFC3339Nano
source: time
- match:
selector: '{exceptionType=~"Gol.Sabre.+"}'
stages:
- json:
expressions:
sabreErrorCode: ExceptionDetail.InnerException.ErrorCode
sabreResponseCode: ExceptionDetail.InnerException.ResponseCode
- labels:
sabreErrorCode: null
sabreResponseCode: null
static_configs: []
- job_name: kubernetes-pods
pipeline_stages:
- cri: {}
relabel_configs:
- source_labels: [__meta_kubernetes_pod_controller_name]
separator: ;
regex: ([0-9a-z-.]+?)(-[0-9a-f]{8,10})?
target_label: __tmp_controller_name
replacement: $1
action: replace
- source_labels: [__meta_kubernetes_pod_label_app_kubernetes_io_name, __meta_kubernetes_pod_label_app,
__tmp_controller_name, __meta_kubernetes_pod_name]
separator: ;
regex: ^;*([^;]+)(;.*)?$
target_label: app
replacement: $1
action: replace
- source_labels: [__meta_kubernetes_pod_label_app_kubernetes_io_component, __meta_kubernetes_pod_label_component]
separator: ;
target_label: component
replacement: $1
action: replace
- source_labels: [__meta_kubernetes_pod_node_name]
separator: ;
regex: (.*)
target_label: node_name
replacement: $1
action: replace
- source_labels: [__meta_kubernetes_namespace]
separator: ;
regex: (.*)
target_label: namespace
replacement: $1
action: replace
- source_labels: [namespace, app]
separator: /
regex: (.*)
target_label: job
replacement: $1
action: replace
- source_labels: [__meta_kubernetes_pod_name]
separator: ;
regex: (.*)
target_label: pod
replacement: $1
action: replace
- source_labels: [__meta_kubernetes_pod_container_name]
separator: ;
regex: (.*)
target_label: container
replacement: $1
action: replace
- source_labels: [__meta_kubernetes_pod_uid, __meta_kubernetes_pod_container_name]
separator: /
regex: (.*)
target_label: __path__
replacement: /var/log/pods/*$1/*.log
action: replace
- source_labels: [__meta_kubernetes_pod_annotationpresent_kubernetes_io_config_hash,
__meta_kubernetes_pod_annotation_kubernetes_io_config_hash, __meta_kubernetes_pod_container_name]
separator: /
regex: true/(.*)
action: replace
static_configs: []
kubernetes_sd_configs:
- role: pod
kubeconfig_file: ""
follow_redirects: true
target_config:
sync_period: 10s
stdin: false
level=error ts=2021-09-24T13:27:54.240306089Z caller=main.go:115 msg="error creating promtail" error="unknown scrape config"
I know the problem is with the job serilog, because if it’s removed from the configuration the pods starts properly.
It’s my first time writing a promtail scrape configuration, I’m pretty sure it’s my fault, but since the dry run works as I expected, now I’m completely lost.
Please if somebody could help, I really appreciate.
- job_name: serilog
pipeline_stages:
- cri: {}
- json:
expressions:
level: '"@l"'
time: '"@t"'
- labels:
exceptionType: null
level: null
requestPath: null
- timestamp:
format: RFC3339Nano
source: time
- match:
stages:
- json:
expressions:
- labels:
