Prometheus false positive alerts
Below is KubeClientCertificateExpiration prometheus alert.
:fire: [FIRING:1] KubeClientCertificateExpiration
Cluster: production-uks-aks
Description: A client certificate used to authenticate to kubernetes apiserver is expiring in less than 24.0 hours.Details:
• endpoint: https
• instance: <server-ip>
• job: apiserver
• namespace: default
• prometheus: service/prometheus-prometheus
• service: kubernetes
• severity: critical```
Looking for clarification on below items.
1. When KubeClientCertificateExpiration alert will trigger.
2. In alert "Description" mentions `client certificate`, could you please confirm which client certificate this is referring to (i.e., is client certificate referring to certificates which are installed locally and used to access Kubernetes cluster. If so why/how prometheus is tracing such client certificates).
Could any one share reference documentation related KubeClientCertificateExpiration. Found one docs related to same here: https://runbooks.prometheus-operator.dev/runbooks/kubernetes/kubeclientcertificateexpiration/, But excepting more information. Awaits your response.
Regards
Karthik Thatipati
