Hi community,
I am trying to do a proxy call over the API to my PSQL database.
Unfortunately, the API is getting a 502 Bad Gateway error.
What I have done:
Get datasource id with this call:
https://[grafana]:3000/api/datasources/
In my case the datasource has the ID 2 -
Do a proxy call:
https://[grafana]:3000/api/datasources/proxy/2/query?query=SELECT%20*%20FROM%20msc_stats%20ORDER%20BY%20time%20DESC%20LIMIT%2010
The answer is a "502 Bad Gateway"
Also this call is getting the 502 error:
https://[grafana]:3000/api/datasources/proxy/2/*
- [grafana] is replaced by the server FQDN
I have formatted the URL in different ways but the server answer is always the same.
Do somebody knows if PSQL support API proxy calls at all? What I am doing wrong?
Many thanks for any hints and compliments to this great product!
Best regards,
Luca
