thanks
Hey,
You really need to start including some more information in your posts. This is like the 10th post I see from you where you only have a title and some minor description. You’ll probably have a lot bigger chance that someone can help you if you try to explain your problem in further detail and include information about what Grafana version you’re using, what operating system you’re running Grafana on and so on.
What Grafana version?
Have you installed Grafana on your Windows machine?
Marcus
version grafana-4.6.3
im install in windows server
Sounds like this: https://github.com/grafana/grafana/issues/9541
It is fixed in the master branch and will be included in the next release of Grafana
Sorry for that. I’ve updated the link
ok thanks for help me
