Persistance docker with grafana2.in in persistance folder
Hi, I’m new on grafana, and I tried to set-up an Grafana Docker, with the settings below.
ID=$(id -u grafana) # saves your user id in the ID variable
docker run -d --name=grafana --user $ID --volume “/volume2/grafana:/var/lib/grafana” --volume “/volume2/grafana/etc:/etc/grafana/” -e “GF_PATHS_CONFIG=/etc/grafana/grafana2.ini” -p 3000:3000 grafana/grafana
I can connect to the docker, but the ini file is still an empty file.
And to use the grafana output in openhab, I need change the ini file.
How can I solve this issue?
I Found that as soon I add
[security]
allow_embedding=true
To the ini file, it works.
