I’m having issues working with the HTTP API, using a service account token for authentication. Please note that other endpoints, such as /api/teams/search work just fine. See a description of my issue below. Any help would be greatly appreciated
Docker, image grafana/grafana-oss:9.3.1
I want to consume the HTTP API with a service account token. Specifically, I want to look up users using the /api/users/lookup endpoint
Create a service account, give it Admin role
Generate token
Perform a get request to url http://api/users/lookup?loginOrEmail=<EMAIL_THAT_IM_LOOKING_FOR>, with header Authorization: Bearer <SERVICE_ACCOUNT_TOKEN>
What happened?
I get the following error message:
“accessErrorId”: “ACE1715412157”,
“message”: “You’ll need additional permissions to perform this action. Permissions needed: users:read”,
“title”: “Access denied”
Get a 2xx response with an array of 0 or more items in the body
I am facing the same issue. Any lead so far?
I updated the Grafana to 10.0.3 but still having the same error
Invoke-RestMethod: {“accessErrorId”:“ACE3712388049”,“message”:“You’ll need additional permissions to perform this action. Permissions needed: users:read”,“title”:“Access denied”}
According to Grafana documentations “Service accounts are limited to an organization and an organization role. They can’t be granted Grafana server administrator permissions.”
But there is a manual solution which I don’t recommend. Connect to grafana database directly which is mysql or sqlite based on your configurations. Update is_admin value of your service account to 1 inside user table.
