Hello k6 Community,
I have a question regarding performance of requests when using ‘k6’ with default support for HTTP/2.0 compared to HTTP/1.1. Sending the same payload (XML file of size: 519 KB, flattened XML file (1 line)) via regular ‘k6’ execution is taking around: 2-2.5 seconds:
INFO[0004] [pwxtt8dvb2] [Thu Feb 15 2024 16:30:53 GMT+0100 (CET)] [TP] SUBMISSION STOP, took: 1801 source=console
INFO[0004] pwxtt8dvb2 blocked 0 source=console
INFO[0004] pwxtt8dvb2 connecting 0 source=console
INFO[0004] pwxtt8dvb2 tls-hs 0 source=console
INFO[0004] pwxtt8dvb2 sending 1560.2153 source=console
INFO[0004] pwxtt8dvb2 waiting 134.8165 source=console
INFO[0004] pwxtt8dvb2 receiving 96.1651 source=console
INFO[0004] pwxtt8dvb2 duration 1791.1969 source=console
Where on HTTP/1.1 when using GODEBUG=http2client=0,http2server=0:
INFO[0203] [75a7j6wqhr] [Thu Feb 15 2024 16:27:18 GMT+0100 (CET)] [API] SUBMISSION STOP, took: 304 ms source=console
INFO[0203] 75a7j6wqhr blocked 0 source=console
INFO[0203] 75a7j6wqhr connecting 0 source=console
INFO[0203] 75a7j6wqhr tls-hs 0 source=console
INFO[0203] 75a7j6wqhr sending 7.6531 source=console
INFO[0203] 75a7j6wqhr waiting 294.6727 source=console
INFO[0203] 75a7j6wqhr receiving 0.9378 source=console
INFO[0203] 75a7j6wqhr duration 303.2636 source=console
My scenario is as follows:
execution: local
script: ./k6/performance-test.js
output: Prometheus remote write (http://localhost:9090/api/v1/write)
scenarios: (100.00%) 4 scenarios, 60 max VUs, 3m50s max duration (incl. graceful stop):
* type2: 0.50 iterations/s for 3m20s (maxVUs: 5-15, exec: sendType2Declaration, gracefulStop: 30s)
* type1: 0.50 iterations/s for 3m20s (maxVUs: 5-15, exec: sendType1Declaration, gracefulStop: 30s)
* type3: 0.15 iterations/s for 3m20s (maxVUs: 5-15, exec: sendType3Declaration, gracefulStop: 30s)
* type4Large: 0.05 iterations/s for 3m20s (maxVUs: 5-15, exec: sendLargeType4Declaration, gracefulStop: 30s)
The only option that I am passing to k6 is:
k6 run ${K6_FILE} \
--config ${SCENARIO} \
-o experimental-prometheus-rw \
--tag runId=${RUN_ID} \
-e RUN_ID=${RUN_ID} \
-e PAYLOADS_DIRECTORY="${PAYLOADS_DIRECTORY}" \
-e HOST="${HOST_URL}" \
--no-vu-connection-reuse
JMeter which is not using HTTP/2.0 is by default responding from an endpoint in around 600 ms. same for Postman collection that is not using HTTP/2.0 as it’s not yet supported as far as I know.
Why does my endpoint return around 6-7 times slower than the one being connected to via HTTP/1.1 protocol?
Thank you for your responses. ![]()
