10.2.2 Windows -
Get the Percentage Trend to show data -
Downloaded and installed the panel, then added two querys and tested them by using the stat panel and two different data was showing, then shosed one of the data fields on percentage value and one on Base Value -
What happened?
Got “Selected Series not avalible” but when shosing Table View i can see data from both querys -
To see the panel with data -
Got Selected series are not avalible -
Percentage Trend plugin for Grafana | Grafana Labs
Thanx
