Hello, i’m newbie on Grafana world and i’m trying to develop DataSourse plugin using WebSocket.
That is not so easy and i really need the community helps!
I have a dashbard with variable(combox), i want to pass the value selected from dashboard to datasourse plugin everytime when the user change the selection.
My DataSourse Plugin is:
import {
CircularDataFrame,
DataQueryRequest,
DataQueryResponse,
DataSourceApi,
DataSourceInstanceSettings,
FieldType,
LoadingState
} from '@grafana/data';
import { MyQuery, MyDataSourceOptions } from './types';
import { merge, Observable } from 'rxjs';
import { io, Socket } from "socket.io-client";
export class DataSource extends DataSourceApi<MyQuery, MyDataSourceOptions> {
ws: Socket<any, any>;
dashboardUID: string | undefined;
constructor(instanceSettings: DataSourceInstanceSettings<MyDataSourceOptions>) {
super(instanceSettings);
this.ws = initWebSocket(instanceSettings.jsonData.path || '');
query(options: DataQueryRequest<MyQuery>): Observable<DataQueryResponse> {
const observables = options.targets.map((target) => {
return new Observable<DataQueryResponse>((subscriber) => {
const frame = new CircularDataFrame({
append: 'tail',
capacity: 2
frame.refId = target.refId;
frame.addField({ name: 'time', type: FieldType.time });
frame.addField({ name: 'data', type: FieldType.other });
this.ws.on("push", (event: any) => {
frame.add(JSON.parse(event));
subscriber.next({
data: [frame],
key: target.refId,
state: LoadingState.Streaming,
return merge(...observables);
async testDatasource() {
return {
status: 'success',
message: 'Success',
function initWebSocket(url: string) {
let wsConn: Socket<any, any>
wsConn = io(url, {
transports: ["websocket"]
wsConn.on('error', (error: any) => {
console.log(`WebSocket error: ${error}`);
return wsConn
I saw similar MSSql plugin, we can use ${VAR_NAME} into a quary and the DS convert the var_name to value selected by user.
How can i do something like this?
