I am trying to use chrome directly to crate a snapshot. I keep getting stuck with the login screen. I have enabled [auth.basic] and tried:
./chrome.exe --headless --disable-gpu --screenshot=C:/tmp/screenshot.png http://admin:admin@community.grafana.com/
Any other options I should try? Is there anyway to pass credentials/api key in the URL?
Thanks for any pointers
