I have an outgoing webhook, but I got an error “URL: This URL is not supported for outgoing webhooks.”. The URL used has also been created in FQDN format. How do I solve this problem?
did you manage to get this solved? I encounter the same problem
@quickyjoe @onc I am stuck on same issue, were you able to fix this ?
Hi, can you share the link? Or at least how it looks like?
I ran into the same error message with the outgoing webhook. Somehow, I found out that I needed to go to OnCall → Settings → Env Variables and set DANGEROUS_WEBHOOKS_ENABLED (Enable outgoing webhooks to private networks) to true.
Probably it also could be achieved by editing config’s security section, but I have no access there.
[security]
allowed_outbound_links =
