Optimize a long query with influxdb
Hello!
I´m using:
Grafana
InfluxDB: v2.7.3
I like to display the consumption of each month from my smartmeter:
import "timezone"
import "date"
option location = timezone.location(name: "Europe/Vienna")
startDate = date.truncate(t: today(), unit: 1y)
from(bucket: "home")
  |> range(start: startDate, stop: now())
  |> filter(fn: (r) => r["_measurement"] == "PV")
  |> filter(fn: (r) => r["Powermeter"] == "Hauptzaehler")
  |> filter(fn: (r) => r["_field"] == "Total Geliefert" or r["_field"] == "Totaler Bezug")
  |> aggregateWindow(every: 1d, fn: last, createEmpty: false)
  |> filter(fn: (r) => r["_value"] > 0)
  |> difference(nonNegative: true)
  |> aggregateWindow(every: 1mo, fn: sum, createEmpty: false)
  |> timeShift(duration: -1s, columns: ["_time"])
  |> yield()
After a loooong waiting time, I get the result:
Is my query very slow?
Hi @hhoe
Is your electricity meter value always increasing? If yes, perhaps using the spread function will be more efficient? Something like this:
import "timezone"
import "date"
  |> aggregateWindow(every: 1mo, fn: spread, createEmpty: false)
  |> yield()
Thank you @grant2
Yes, its always increasing. But this dont work:
I`m thinking also about this direction:
import "timezone"
import "date"
seven = from(bucket: "house")
  |> range(start: date.add(d: 6mo, to: startDate), stop: date.add(d: 1d, to: date.add(d: 6mo, to: startDate)))
  |> first()
eight = from(bucket: "house")
  |> range(start: date.add(d: 7mo, to: startDate), stop: date.add(d: 1d, to: date.add(d: 7mo, to: startDate)))
  |> first()
nine = from(bucket: "house")
  |> range(start: date.add(d: 8mo, to: startDate), stop: date.add(d: 1d, to: date.add(d: 8mo, to: startDate)))
  |> first()
sum = union(tables: [seven, eight, nine])
    |> pivot(rowKey: ["_time"], columnKey: ["_field"], valueColumn: "_value")
sum
//  |> difference(nonNegative: false)
  |> yield()
But it seems he don´t combine the 3 queries correct to one result.
I just need always the value closest to the first or last in a month
Hi @hhoe
I feel this can still be done in one query. Can you try this?
import "timezone"
import "date"
  |> aggregateWindow(every: 1mo, fn: last, createEmpty: false)
  |> yield()
Thank you @grant2
This is similar my first post and the query takes very long.
Yeah, I thought that maybe having one aggregateWindow function (instead of two) might speed up your query. I wish there was a way to show what in your query is causing it to take so long.
Are there any other tags in your data that can be filtered so that the dataset is smaller before running the aggregateWindow funcdtion.
I tried now to read all data for 1 year. Data available from April.
He read the data withing 1s!
When I use:
|> aggregateWindow(every: 1d, fn: mean, createEmpty: false)
he need around 1s
When I use:
he need around 10s
Did you know why last has this delay?
With mean ne need to read all values and calc the mean
With last or first he “just” need the first value
Why is mean so fast?
That is puzzling! Maybe ask this question in the Influx forum if you have not already done so.
I saw you had posted already there, but this specific question might lead to the answer as to why the query takes so long.
Is Powermeter a field ir a tag?
Very important read
