7.5.2 -
setting up alert on metric which evaluates every one min for 0
and alert condition on median of query (B, 5m, now) and is above 100.
since alert condition on median i was hoping to alert only if 3 data points are reached the threshold it triggers alert but it alerts even if one value reached the threshold
- How are you trying to achieve it?
Through alert config
What happened?
it alerts even if one value reached the threshold -
since alert condition on median i was hoping to alert only if 3 data points are reached the threshold it triggers alert -
“alert”: {
“alertRuleTags”: {},
“conditions”: [
“evaluator”: {
“params”: [
100
“type”: “gt”
“operator”: {
“type”: “and”
“query”: {
“params”: [
“B”,
“5m”,
“now”
“reducer”: {
“params”: ,
“type”: “median”
“type”: “query”
“executionErrorState”: “keep_state”,
“for”: “0m”,
“frequency”: “1m”,
“handler”: 1,
none -
