Hi dear people,
I’m struggling while implementing an own data source plugin for an AWS service, which should be very similar to the Redshift data source and the Athena data source (async implementation). That’s why my plugin is mostly a copy & past from those two plugins, which use the grafana-aws-sdk.
However, as soon as I query the backend plugin, I get as response from /query:
{"message":"Not implemented","messageId":"plugin.notImplemented","statusCode":501,"traceID":""}
I read that this means (usually?) that the QueryData method is not implemented, as clearly stated in the generated datasource.go. Indeed, I did not implement this, but it should be inherited from grafana-aws-sdk’s asyncDatasource.go.
But maybe, exactly this is not the case? I would very much appreciate your help - my Go experience is rather limited. My code is here.
10.1 on MacOS -
Implement a data source plugin for AWS CloudTrail Lake -
Copy & Paste from Athena and Redshift data sources -
What happened?
I messed it up -
Would be optimistic to say that it should work. -
GitHub StephenKing/grafana-cloudtraillake-datasource -
logger=context userId=0 orgId=1 uname= t=2023-10-21T20:17:36.877627012Z level=debug msg="Not implemented" error="[plugin.notImplemented] method not implemented" remote_addr=192.168.228.1 traceID=
logger=context userId=0 orgId=1 uname= t=2023-10-21T20:17:36.877713679Z level=error msg="Request Completed" method=POST path=/api/ds/query status=501 remote_addr=192.168.228.1 time_ms=8 duration=8.280622ms size=95 referer="http://localhost:3000/explore?left=%7B%22datasource%22%3A%22d10f5f20-4590-4eb1-9326-04643eb911d2%22%2C%22queries%22%3A%5B%7B%22format%22%3A1%2C%22rawSQL%22%3A%22asdasdasd%22%2C%22connectionArgs%22%3A%7B%22region%22%3A%22__default%22%7D%2C%22refId%22%3A%22A%22%2C%22datasource%22%3A%7B%22type%22%3A%22emnify-cloudtraillake-datasource%22%2C%22uid%22%3A%22d10f5f20-4590-4eb1-9326-04643eb911d2%22%7D%7D%5D%2C%22range%22%3A%7B%22from%22%3A%22now-1h%22%2C%22to%22%3A%22now%22%7D%7D&orgId=1" handler=/api/ds/query
- Did you follow any online instructions? If so, what is the URL?
Build a data source backend plugin | Grafana Plugin Tools
P.S: sorry that I’m not properly linking resources, but as (rather) new user, I can only include 2 links in my posting.
