Not able to access environment variables in init phase (k6-operator)
As the title suggests, I am not able to access environment variables in the init phase when running distributed tests. It works fine locally.
Here is my CRD:
apiVersion: k6.io/v1alpha1
kind: K6
metadata:
spec:
  parallelism: 2
  script:
    configMap:
      file: perf-test.js
  arguments: ' --tag test_run_id=Wed_Nov__1_08:53:42_PDT_2023'
  runner:
    env:
      - name: TEST_TYPE
        value: "soft"
Here is the init code:
import http from 'k6/http';
import { sleep, group, check } from 'k6';
const stage_configs = {
    soft: [
        { duration: '30s', target: '10'},
        { duration: '14m', target: '10'},
        { duration: '30s', target: '0'}
    medium: [
        { duration: '30s', target: '160'},
        { duration: '14m', target: '160'},
    hard: [
        { duration: '30s', target: '2000'},
        { duration: '14m', target: '2000'},
export const options = {
    discardResponseBodies: true,
    stages: []
const test_type = __ENV.TEST_TYPE;
options.stages = stage_configs[test_type];
Thank you in advance!
Hi @rajmehta53 !
On my cluster your example produces an error message in the k6-operator-controller-manager
ERROR	controllers.K6	Parallelism argument cannot be larger than maximum VUs in the script	{"namespace": "default", "name": "perf-test", "reconcileID": "5c6d8c57-974f-400e-ad40-9d7d92f2f944", "maxVUs": 1, "parallelism": 2, "error": "number of instances > number of VUs"}
If I understand right this is because k6-operator runs an initializer job prior test run jobs. Initializer job is basically a k6 inspect command run. Although k6 inspect allows environment variables (via the flag -e), k6-operator doesn’t pass such flag to k6 inspect. see here the source. I don’t know if it is intentional or not. Because of this, environment variables are unavailable in the initializer job. So when you write:
__ENV.TEST_TYPE is undefined, and options.stages also become undefined, and k6-operator doesn’t even start the test with the error message above.
Workaround:
I don’t know if this workaround produces a correct result or not, but you can trick initializer job with whatever stages value that needs more VU than the set parallelism. After k6-operator starts the test run jobs, the environment variables will be available.
So. Long story short, try this line:
const test_type = __ENV.TEST_TYPE || 'soft';
instead of this:
Hey @bandorko !
Thank you for your response. I already tried the workaround you mentioned, but it defaults to the ‘soft’ stage always since __ENV.TEST_TYPE is always empty.
This defeats the purpose of passing the test type as an environment variable. I wanted to decouple this so that we don’t need to change anything in the test script.
@rajmehta53
I experienced, that with this workaround, the initializer job thinks, that the test will run on 10 VU’s, but the actual test run performed with higher VU count (2x80) if you run it with medium TEST_TYPE.
Interesting. But it didn’t work for me. I set the test_type to medium and parallelism to 1. The end of test results on the pod still showed 10 users, instead of the increased number in medium.
@rajmehta53
After test run finished on ‘medium’ TEST_TYPE I have 4 pods
NAME                          READY   STATUS      RESTARTS   AGE
perf-test-1-txp22             0/1     Completed   0          4m17s
perf-test-2-klr86             0/1     Completed   0          4m17s
perf-test-initializer-6kzq6   0/1     Completed   0          4m30s
perf-test-starter-66phw       0/1     Completed   0          3m55s
the logs:
> kubectl logs perf-test-1-txp22
     data_received........: 0 B    0 B/s
     data_sent............: 0 B    0 B/s
     iteration_duration...: avg=256.99µs min=3.05µs med=3.87µs max=1.08s p(90)=7.53µs p(95)=9.25µs
     iterations...........: 272263 13555.7368/s
     vus..................: 28     min=0        max=80
     vus_max..............: 80     min=80       max=80
> kubectl logs perf-test-2-klr86
     iteration_duration...: avg=174.2µs min=2.86µs med=3.85µs max=1.09s p(90)=7.52µs p(95)=9.12µs
     iterations...........: 295271 14701.22307/s
     vus..................: 27     min=0         max=80
> kubectl logs perf-test-starter-66phw
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   238  100   151  100    87  24257  13975 --:--:-- --:--:-- --:--:-- 30200
100   238  100   151  100    87  82739  47671 --:--:-- --:--:-- --:--:--  147k
{"data":{"type":"status","id":"default","attributes":{"status":4,"paused":false,"vus":0,"vus-max":80,"stopped":false,"running":false,"tainted":false}}}{"data":{"type":"status","id":"default","attributes":{"status":4,"paused":false,"vus":0,"vus-max":80,"stopped":false,"running":false,"tainted":false}}}
> kubectl logs perf-test-initializer-6kzq6
  "paused": null,
  "vus": null,
  "duration": null,
  "iterations": null,
  "stages": [
      "duration": "3s",
      "target": 10
      "duration": "14s",
      "target": 10
      "duration": "3s",
      "target": 0
  "scenarios": {
    "default": {
      "executor": "ramping-vus",
      "startTime": null,
      "gracefulStop": null,
      "env": null,
      "exec": null,
      "tags": null,
      "startVUs": null,
      "stages": [
          "duration": "3s",
          "target": 10
          "duration": "14s",
          "target": 10
          "duration": "3s",
          "target": 0
      "gracefulRampDown": null
  "executionSegment": null,
  "executionSegmentSequence": null,
  "noSetup": null,
  "setupTimeout": null,
  "noTeardown": null,
  "teardownTimeout": null,
  "rps": null,
  "dns": {
    "ttl": null,
    "select": null,
    "policy": null
  "maxRedirects": null,
  "userAgent": null,
  "batch": null,
  "batchPerHost": null,
  "httpDebug": null,
  "insecureSkipTLSVerify": null,
  "tlsCipherSuites": null,
  "tlsVersion": null,
  "tlsAuth": null,
  "throw": null,
  "thresholds": null,
  "blacklistIPs": null,
  "blockHostnames": null,
  "hosts": null,
  "noConnectionReuse": null,
  "noVUConnectionReuse": null,
  "minIterationDuration": null,
  "ext": null,
  "summaryTrendStats": [
    "avg",
    "min",
    "med",
    "max",
    "p(90)",
    "p(95)"
  "summaryTimeUnit": null,
  "systemTags": [
    "check",
    "error",
    "error_code",
    "expected_response",
    "group",
    "method",
    "name",
    "proto",
    "scenario",
    "service",
    "status",
    "subproto",
    "tls_version",
    "url"
  "tags": {
    "test_run_id": "Wed_Nov__1_08:53:42_PDT_2023"
  "metricSamplesBufferSize": null,
  "noCookiesReset": null,
  "discardResponseBodies": true,
  "totalDuration": "50s",
  "maxVUs": 10
So for me, the initializer pod shows 10 VUs, but the starter and the runners show 160 VUs
Hey @bandorko !
That actually worked. Thank you so much for your help, really appreciate it.
hi @bandorko i am following exactly this and getting error :
{"namespace": "argo", "name": "load-test", "reconcileID": "2dc76eba-d8e8-4978-bd34-9889d9c268e1", "error": "invalid character 'i' in literal true (expecting 'r')"}
github.com/grafana/k6-operator/controllers.inspectTestRun
I am uisng k6 operator for using k6 and invocating it via argo workflows
following is my script
export let options = {
    scenarios: {
        ramping_arrival_rate: {
            executor: 'ramping-arrival-rate',
            startRate: parseInt(__ENV.START_RATE || '500'), // Use env var or default
            timeUnit: __ENV.TIME_UNIT || '1s', // Use env var or default
            preAllocatedVUs: parseInt(__ENV.PRE_ALLOCATED_VUS || '5000'), // Use env var or default
            maxVUs: parseInt(__ENV.MAX_VUS || '15000'), // Use env var or default
            stages: JSON.parse(__ENV.OPTIONS || '[{"target": 1500, "duration": "1m"}, {"target": 3500, "duration": "2m"}, {"target": 3500, "duration": "2m"}, {"target": 1500, "duration": "2m"}, {"target": 0, "duration": "1m"}]'), // Parse JSON from env var or use default
    // Discarding response bodies is a good practice for performance unless you need to check the content.
    // discardResponseBodies: true,
and in stages I am passing
'[{"target": 2, "duration": "1m"}, {"target": 4, "duration": "2m"}]'
my logs of k6 operator
controllers.TestRun	unable to marshal: `time="2025-07-27T08:01:00Z" level=info msg=undefined source=console
time="2025-07-27T08:01:00Z" level=info msg="=== DEBUG ENV VARIABLES ===" source=console
time="2025-07-27T08:01:00Z" level=info msg="OPTIONS exists: undefined" source=console
time="2025-07-27T08:01:00Z" level=info msg="OPTIONS length: 0" source=console
time="2025-07-27T08:01:00Z" level=info msg="First 50 chars: " source=console
time="2025-07-27T08:01:00Z" level=info msg="Last 50 chars: " source=console
time="2025-07-27T08:01:00Z" level=info msg="Raw OPTIONS: undefined" source=console
time="2025-07-27T08:01:00Z" level=info msg="================================" source=console
  "paused": null,
  "vus": null,
  "duration": null,
  "iterations": null,
  "stages": null,
  "scenarios": {
    "ramping_arrival_rate": {
      "executor": "ramping-arrival-rate",
      "startTime": null,
      "env": null,
      "exec": null,
      "tags": null,
      "startRate": 500,
      "timeUnit": "1s",
      "stages": [
          "duration": "1m0s",
          "target": 1500
          "duration": "2m0s",
          "target": 3500
          "duration": "2m0s",
          "target": 3500
          "duration": "2m0s",
          "target": 1500
          "duration": "1m0s",
          "target": 0
      "preAllocatedVUs": 5000,
      "maxVUs": 15000
  "noSetup": null,
  "noTeardown": null,
  "rps": null,
  "dns": {
    "ttl": null,
    "select": null,
    "policy": null
  "userAgent": null,
  "batch": null,
  "httpDebug": null,
  "tlsVersion": null,
  "tlsAuth": null,
  "throw": null,
  "thresholds": null,
  "hosts": null,
  "ext": null,
    "avg",
    "min",
    "med",
    "max",
    "p(90)",
    "p(95)"
  "systemTags": [
    "check",
    "error",
    "error_code",
    "group",
    "method",
    "name",
    "proto",
    "scenario",
    "service",
    "status",
    "subproto",
    "tls_version",
    "url"
  "tags": {
    "testid": "1"
  "discardResponseBodies": null,
  "totalDuration": "8m30s",
  "maxVUs": 15000
}`	{"namespace": "argo", "name": "load-test", "reconcileID": "2dc76eba-d8e8-4978-bd34-9889d9c268e1", "error": "invalid character 'i' in literal true (expecting 'r')"}
	/workspace/controllers/common.go:112
github.com/grafana/k6-operator/controllers.RunValidations
	/workspace/controllers/k6_initialize.go:55
github.com/grafana/k6-operator/controllers.(*TestRunReconciler).reconcile
	/workspace/controllers/testrun_controller.go:141
github.com/grafana/k6-operator/controllers.(*TestRunReconciler).Reconcile
	/workspace/controllers/testrun_controller.go:84
sigs.k8s.io/controller-runtime/pkg/internal/controller.(*Controller[...]).Reconcile
	/go/pkg/mod/sigs.k8s.io/controller-runtime@v0.20.3/pkg/internal/controller/controller.go:118
sigs.k8s.io/controller-runtime/pkg/internal/controller.(*Controller[...]).reconcileHandler
	/go/pkg/mod/sigs.k8s.io/controller-runtime@v0.20.3/pkg/internal/controller/controller.go:328
sigs.k8s.io/controller-runtime/pkg/internal/controller.(*Controller[...]).processNextWorkItem
	/go/pkg/mod/sigs.k8s.io/controller-runtime@v0.20.3/pkg/internal/controller/controller.go:288
sigs.k8s.io/controller-runtime/pkg/internal/controller.(*Controller[...]).Start.func2.2
	/go/pkg/mod/sigs.k8s.io/controller-runtime@v0.20.3/pkg/internal/controller/controller.go:249
