No date field named timestamp found
trying to create a new elasticsearch datasource produces the following error “No date field named timestamp found”
The data was created using the following format;
‘{ “user”:“user.1”, “timestamp”: 337712739, “type”: “date”, “format”: “epoch_second” }’
And the mapping produces the following…
“monitor” : {
“mappings” : {
“rbt” : {
“properties” : {
“format” : {
“type” : “text”,
“fields” : {
“keyword” : {
“type” : “keyword”,
“ignore_above” : 256
“timestamp” : {
“type” : “long”
“type” : {
“type” : “text”,
“fields” : {
“keyword” : {
“type” : “keyword”,
“user” : {
“type” : “text”,
“fields” : {
“keyword” : {
“type” : “keyword”,
Any ideas?
Thanks
Create elasticsearch index date mapping field like and date format should be like
"properties" : { "serverDate": { "type": "date"   , "index" : "true"  , "format": "strict_date_optional_time||epoch_millis" }}
Date format should be ’ 2018-06-21T09:44:17Z’ (‘Y-m-d\TH:i:s\Z’)
