New table visualization doesn't work well with time field
In latest version “7” there has been introdution to the new metric logs. On previous version I was using raw log and data table transform json data to filter columns that I want to be shown.
Currently I had to use “Logs” Metric and Transformation to achieve the same result. Unfortunately, field that contains time, doesn’t work well with overrides and time zones.
Previous version:
2020-06-24 09:08:48.811
Column Styles
Options
Name pattern
@timestamp
Column Header
Time
Render value as link
Type
Type
Date
Date Format
YYYY-MM-DD HH:mm:ss.SSS
Align
auto
Actual Version:
2020-06-24T07:01:34.892Z
Override 1
Matcher
Filter by field
Set properties for fields matching the name
@timestamp
Unit
Display name
Change the field or series name
Time
Both panels are on the same dashbord so the difference is quite visible.
Is there a way to change this @timestamp field to achieve right timezone and time format?
You have said “latest version 7” but have not said which specific version 7 you are running. You also have not said what your datasource is or what your query is. I suggest you supply those details.
Ofcourse,
Grafana 7.0.3 and source Data Elasticsearch.
same here Grafana 7.1.5 , elasticsearch data source
