Hi
I have a simple test to skeleton project in spring framework
export default function() {
http.get(‘http://localhost:8080/hello’);
When I execute the test docker-compose run k6 run /tests/02-stages/skeletonProject.js
I see an error message : error=“Get http://localhost:8080/hello: dial tcp 127.0.0.1:8080: connect: connection refused”
This is a standard connection error unrelated to k6. Since you’re running inside a Docker container, and if the service you’re testing is exposed on the host network, you’ll need to access it via the Docker bridge interface, run with --net=host, or run the service itself from another container part of the same Compose stack.
See the answers on this SO question for details and other suggestions.
