Im using a singlestat panel (prometheus data), and I want to see if the current value is NaN.
As I see on the singlestat docs, it will not show the last, but the last not null:
"current - The last value in the series. If the series ends on null the previous value will be used."
http://docs.grafana.org/features/panels/singlestat/
Is there any way to show it (with “NaN” or any value mapping)?
thanks!
