Multiple scenarios failing on API calls
Hi all, Can someone help? When I run scenarios separately everything looks good. If I run it as multiple scenarios(loadTest.js) I got APIs response status codes 403 or 500 instead of 200
// loadTest.js
import { scenario1 } from './scenario1.js';
import { scenario2 } from './scenario2.js';
export let options = {
  thresholds: {
    error_rate: ['rate < 0.1'],
  scenarios: {
    scenario1: {
      executor: 'ramping-vus',
      startVUs: 0,
      stages: [
        { duration: '30s', target: 5 },
      gracefulRampDown: '10s',
    scenario2: {
      startVUs: 0,
      stages: [
export default function() {
  scenario1()
  scenario2()
// scenario1.js
import { sleep, group, check } from 'k6'
import { parseHTML } from "k6/html";
import { fail } from "k6";
import http from 'k6/http'
import {
  serverUrl,
  errorRate,
  scenario1user,
} from "./config.js";
import  {
  getRandomNumberBetween,
  getCsrfTokenFromResponse,
  loginWeb,
  getPatientIDAfterLogin,
  getCookieFromResponse,
}  from "./tools.js";
export function scenario1() {
  var response;
  var token ="";
  var token1 ="";
  var masterUrl = serverUrl;
  var userName = scenario1user;
  var password = "abc123";
  var patientID = "";
  var cookie = "";
  var status = true;
  group("scenario1", function () {
    response = http.get(masterUrl+"/users/signin");
    token = getCsrfTokenFromResponse(response);
    response =	loginWeb(token, userName, password, masterUrl);
    var result = check(response, {'login': res => res.status === 200});
    errorRate.add(result ? 0 : 1);
    //+ other APIs
  sleep(1)
// scenario2.js
import {
  serverUrl,
  errorRate,
  scenario2user,
import  {
  loginWeb,
export function scenario2() {
  var response;
  var token ="";
  var token1 ="";
  var userName = scenario2user;
  var patientID = "";
  var cookie = "";
  var status = true;
  group("scenario2", function () {
    //+ other APIs
  sleep(1)
I found the problem… scenarios share data…how I can avoid that? For example. If I log in as an admin user in one scenario, And if I try to login as a user in another scenario I will get admin user data as a response from the user API log in
resolved
added in loadtest.js:
  scenarios: {
    scenario1: {
      exec: 'scenario1A', // add this
      startVUs: 0,
      stages: [
   scenario2: {
     exec: 'scenario2A', // add this
      startVUs: 0,
      stages: [
and add this
export function scenario1A() {
 scenario1();
export function scenario2A() {
 scenario2();
instead of
  scenario1()
  scenario2()
Hi @cinco107, Sorry for the late reply.
But yes as you’ve noticed just naming stuff scenario doesn’t make them one :). In reality, your code was executing the same default functions in two different executors instead of executing scenario1 in one of them and scenario2 in the other.
I hope you now understand this, but if you can provide any advice on what wasn’t clear or if anything else seems unclear to you, we can update the documentation accordingly.
