Hello friends,
I have connection issues if I try to add a mssql datasource with a named instance.
We have 2 named instances running on the same host:
Host: db02
Named instance 1: erp
Named instance 2: app
If I add a database from the named instance “erp” and enter “db02\erp” the Host field, it works:
If I try to add a database from the named instance “app”, and enter “db02\app” in the host field, I receive a connection refused error:
The credentials that I use are correct, and were verified multiple times using SQL Server Managament Studio.
There is another thing that I’ve noticed going through the connection logs of the SQL server:
If I enter “db02\erp” or even just “db02”, without the instance name, inside the Host field, Grafana is establishing a connection with the “erp” named instance.
If I enter “db02\app” inside the Host field, Grafana is still trying to establish a connection with the “erp” named instance, instead of the “app” instance that is used.
It looks like Grafana would completely ignore everything that comes after the “” backslash and instead is just targeting the default instance “erp”.
The Grafana version that I’m using is 7.3.6.
Am I missing something? Any suggestions?
Best regards
