im using Grafana 9.1.6 an i just installed the MQTT plugin. As you can see in the picture, i use the stat panel with multiple queries.
Unfortunately i am not able to use the override function in here because all queries are named Value.
The first value should be: Voltage 41.1 V
The second value should be: Current 1.35 A
So how can i rename it and add a unit for each query?
