Is it possible to monitor RDS replica lag in grafana cloud? I have our primary RDS instance sending data to grafana cloud but I cannot seem to find any RDS replication-related metrics. My replica is tagged and I’m getting some metrics, just not the ReplicaLag data. What gives?
Hello, at the moment the integration does not support pulling in the ReplicaLag metric. You can see which metrics are currently supported for RDS in our documentation, CloudWatch metrics integration | Grafana Cloud documentation. We are actively working on expanding the number of metrics supported as well as allowing you to pick the metrics and statistics you would like. The ReplicaLag metric will be an option when this feature is released.
Oh dang. Ok, thanks for that though!
