I have several dashboards that have some help documentation built into the descriptions of the panels and I can see the text of the descriptions in the json file that I export from Grafana. Is it possible to modify these files either manually or in mass without corrupting them?
Related topics
| Topic | Replies | Views | Activity | |
| Possible way to simplify exporting dashboards for use in Grafana app plugins? | 2 | 1502 | January 13, 2021 | |
| Update dashboard JSON supported in Grafana 5.0.1? | 0 | 556 | March 15, 2018 | |
| Import doesn't work without manual edit of exported dashboard | 5 | 1975 | May 10, 2018 | |
Is there an API where i can export grafana dashboard with current snapshot of data
0 | 266 | August 6, 2020 | |
| Split dashboard json file into json panels' files | 1 | 1038 | August 30, 2018 |
