Mixed plot type in a plot container-- lines and points
I’m relatively new to Grafana. I am interfacing Grafana with a MySQL DB. I have data from multiple sources I want in the same plot panel. One data source has high frequency data (5 min) and I want that plotted as a line. Another data source has low frequency data (e.g., every couple hours) and I want that plotted as points. It seems for a given plot container, you must select line, point or bar and all datasets will be plotted in that manner.
I’ve done some searching for a solution, but I have not found one, perhaps because this isn’t possible. The only solution may be to put the other dataset in a different plot container?
Thanks,
Justin
you the style overrides to set display options per series
https://community.grafana.com/t/advanced-graphing-part1-style-overrides/207
Thank you so much! Exactly what I needed.
