Missing logs in Loki
issue: logs missing in loki
description: I am in the process of migrating from ELK to Loki. I have set up Loki in distributed mode and container S3 as log storage. All services are working fine but when I compare logs between Loki and already running ELK, i see a lot of logs missing in Loki. This is a show stopper from going further with Loki set up.
Thanks
Eswar
Hello.
I’m having the same problem.
I have fluentbit as client, output is set to cloudwatch logs and loki.
But when I compare the number of loglines per hour in cloudwatch and loki, there is a difference.
Some hours they match perfectly, but some hours there is a significant amount of missing logs in loki, around 40,000 loglines.
Have you resolved this now?
