Missing Data Points otel->datadog
Does anyone encountered an issue with metric submission throw otel to datadog?
In a very low load, about 5 users, I encountered datapoints drop.
This is my confuguration:
otel config
receivers:
  filelog:
    include_file_name: false
    poll_interval: 50ms
    include:
      - /*/k6-logs.log
    start_at: beginning
    operators:
      - type: regex_parser
        parse_from: body
        regex: 'time="(?P<time>[^"]+)" level=(?P<level>\w+) msg="(?P<msg>.+?)" source=(?P<source>\w+)( .+)?'
        on_error: drop_quiet
        parse_from: attributes.msg
        regex: '\[(?P<user>[^\@]+)@(?P<tangles>[^\]]+)\]'
        on_error: send_quiet
        scope: attributes
      - type: time_parser
        parse_from: attributes.time
        layout: '%Y-%m-%dT%H:%M:%SZ'
  otlp:
    protocols:
      http:
        endpoint: localhost:4318
exporters:
  datadog:
    api:
      key: "{{ DATADOG_API_KEY }}"
      site: "datadoghq.com"
processors:
  batch/datadog:
    send_batch_max_size: 100
    send_batch_size: 10
    timeout: 10s
  attributes:
    actions:
      - key: service
        value: "k6"
        action: insert
      - key: ddtags
        value: "build_id:${env:BUILD_BUILDID}"
        action: insert
service:
  pipelines:
    metrics:
      receivers: [otlp]
      processors: [batch/datadog]
      exporters: [datadog]
    logs:
      receivers: [otlp, filelog]
      processors: [batch/datadog, attributes]
Hey @idosegal,
unfortunately, without any additional information it might be difficult to provide any help.
Can you please report if you got any log lines or errors? Did you try to push through a different service (maybe one locally hosted)?
