I have a remote device which has Grafana Agent installed and connected to Grafana Cloud which receives some Prometheus metrics. The device might be without internet access for an extended period of time (e.g. 2-3 hours) before connecting again. In this case I see that the metrics are being deleted and when there is internet again these 2 hours of data are not filled up.
I have tried updating the min_wal_time to 3h which is what I understood that would help for that here but I am still losing this data. I am using the default wal_directory: /tmp/grafana-agent-wal
. Here is a simplified version of my Grafana Agent config:
server:
log_level: info
metrics:
wal_cleanup_period: 2h
http_idle_conn_timeout: 1h
configs:
- name: integrations
remote_write:
- basic_auth:
password: <psw>
username: <username>
url: <url>
min_wal_time: 3h
max_wal_time: 6h
wal_truncate_frequency: 2h
write_stale_on_shutdown: true
scrape_configs:
- job_name: job-prometheus-metrics
static_configs:
- targets:
- localhost:8000
labels:
instance: instance-name
scrape_interval: 5s
global:
scrape_interval: 30s
logs:
configs:
- name: default
clients:
- basic_auth:
password: <psw>
url: <url>
positions:
filename: /tmp/positions.yaml
target_config:
sync_period: 10s
scrape_configs:
- job_name: custom-job
static_configs:
- targets:
- localhost
labels:
instance: instance_name
job: custom-job
__path__: /file_location.smt
integrations:
node_exporter:
enabled: true
instance: device
prometheus_remote_write:
- basic_auth:
password: <psw>
url: <url>
How can I keep this data locally till they are uploaded to Grafana Cloud, so I will not lose them?
