9.1.7 on CentOS 8 -
What happened?
I have created a panel and max value looks good. Seems max is 540, the largest of all values:
But when the panel is viewed via an “embedded” url, the max is looking different, way larger:
/grafana/d-solo/JYRInkcGz/luftfugtighed-kaelder?orgId=1&from=1664521174529&to=1665125974529&panelId=8&max=1 -
