xk6-plugin v0.1.0 is here
Create k6 plugins using JavaScript and Node.js
The xk6-plugin k6 extension makes the Node.js runtime available to k6 tests using k6 plugins. Plugins are executed by a modern Node.js compatible runtime (Deno or Bun), so they can use the entire Node.js ecosystem.
In simple terms, a plugin is nothing more than a JavaScript (or TypeScript) module executed on the Node.js runtime, whose exported functions are available from k6 tests. Both Deno and Bun runtimes are supported.
Features
- the entire Node.js ecosystem is available, millions of packages
- plugins can be written in TypeScript/JavaScript
- modern Node.js compatible JavaScript runtime (Deno or Bun)
- no go language skills required
- plugin development does not require a custom k6 build
- plugins are ESM modules, no need to learn a new API
- plugins can be tested without k6
- k6 tests and plugins can be written in the same language
Quick start
Download the archive from the Releases page for your operating system and extract the
k6executable from it. -
Create a plugin, let’s say
hello.plugin.js:export function hello() { return "Hello, World!" } -
Create a k6 test script that uses this plugin, let’s say
script.js:import { hello } from "k6/x/plugin/./hello.plugin.js" export default async function() { console.log(await hello()) } -
Run the k6 test script:
k6 run -q --no-summary script.jsYou will get something like this output:
INFO[0000] deno 2.2.2 started with ./hello.plugin.js INFO[0000] Hello, World! source=console
Congratulations, you have created and used your first k6 plugin!
