Loki-write autoforget_unhealthy flag
Hi! We’re facing an issue with loki-write and we want to know if the ‘autoforget_unhealthy’ flag could help us. A few days ago, we encountered problems in our Kubernetes cluster when we lost a worker that was running a Loki write pod. The error indicated that it was still in the ring, and the only way to resolve it was to access ‘/ring’ and manually forget it.
While researching the Loki documentation, we came across the ‘autoforget_unhealthy’ and we have some questions about its recommended usage, especially in the context of a StatefulSet installation of loki-write.
We did some test with this flag in our dev environment, stopping the container of loki-write through the ec2 instance. It was successfully removed from the ring and then when the container started up the instance went back to the ring too, so everything worked fine.
Do you have any piece of advice? Any recommendation would be greatly appreciated!
We have the following config of loki:
# Configuration for the write pod(s)
write:
 # -- Number of replicas for the write
 replicas: 5
 autoscaling:
   # -- Enable autoscaling for the write.
   enabled: true
   # -- Minimum autoscaling replicas for the write.
   minReplicas: 3
   # -- Maximum autoscaling replicas for the write.
   maxReplicas: 8
   # -- Target CPU utilisation percentage for the write.
   targetCPUUtilizationPercentage: 80
   # -- Target memory utilization percentage for the write.
   targetMemoryUtilizationPercentage: 75
   # -- Behavior policies while scaling.
   behavior:
   # -- see https://github.com/grafana/loki/blob/main/docs/sources/operations/storage/wal.md#how-to-scale-updown for scaledown details
     scaleUp:
       policies:
         - type: Pods
           value: 1
           periodSeconds: 60
     scaleDown:
       policies:
         - type: Pods
           value: 1
           periodSeconds: 60
       stabilizationWindowSeconds: 300
 image:
   # -- The Docker registry for the write image. Overrides `loki.image.registry`
   registry: null
   # -- Docker image repository for the write image. Overrides `loki.image.repository`
   repository: null
   # -- Docker image tag for the write image. Overrides `loki.image.tag`
   tag: null
 # -- The name of the PriorityClass for write pods
 priorityClassName: null
 # -- Annotations for write StatefulSet
 annotations: {}
 # -- Annotations for write pods
 podAnnotations: {}
 # -- Additional labels for each `write` pod
 podLabels: {}
 # -- Additional selector labels for each `write` pod
 selectorLabels: {}
 # -- Labels for ingester service
 serviceLabels: {}
 # -- Comma-separated list of Loki modules to load for the write
 targetModule: "write"
 # -- Additional CLI args for the write
 extraArgs: []
 # -- Environment variables to add to the write pods
 extraEnv: []
 # -- Environment variables from secrets or configmaps to add to the write pods
 extraEnvFrom: []
 # -- Lifecycle for the write container
 lifecycle: {}
 # -- The default /flush_shutdown preStop hook is recommended as part of the ingester
 # scaledown process so it's added to the template by default when autoscaling is enabled,
 # but it's disabled to optimize rolling restarts in instances that will never be scaled
 # down or when using chunks storage with WAL disabled.
 # https://github.com/grafana/loki/blob/main/docs/sources/operations/storage/wal.md#how-to-scale-updown
 # -- Init containers to add to the write pods
 initContainers: []
 # -- Volume mounts to add to the write pods
 extraVolumeMounts: []
 # -- Volumes to add to the write pods
 extraVolumes: []
 # -- volumeClaimTemplates to add to StatefulSet
 extraVolumeClaimTemplates: []
 # -- Resource requests and limits for the write
 resources:
   limits:
     cpu: 2
     memory: 8Gi
   requests:
     cpu: 700m
     memory: 6Gi
 # -- Grace period to allow the write to shutdown before it is killed. Especially for the ingester,
 # this must be increased. It must be long enough so writes can be gracefully shutdown flushing/transferring
 # all data and to successfully leave the member ring on shutdown.
 terminationGracePeriodSeconds: 300
 # -- Affinity for write pods. Passed through `tpl` and, thus, to be configured as string
 # @default -- Hard node and soft zone anti-affinity
 affinity: |
   podAntiAffinity:
     requiredDuringSchedulingIgnoredDuringExecution:
       - labelSelector:
           matchLabels:
             {{- include "loki.writeSelectorLabels" . | nindent 10 }}
         topologyKey: kubernetes.io/hostname
   nodeAffinity:
       nodeSelectorTerms:
       - matchExpressions:
         - key: node-type.nebula.despegar.com/nbl-platform
           operator: Exists
 # -- Node selector for write pods
 nodeSelector: {}
 # -- Tolerations for write pods
 tolerations:
     operator: Exists
     effect: NoSchedule
 # -- The default is to deploy all pods in parallel.
 podManagementPolicy: "Parallel"
 persistence:
   # -- Enable StatefulSetAutoDeletePVC feature
   enableStatefulSetAutoDeletePVC: false
   # -- Size of persistent disk
   # -- Storage class to be used.
   # If defined, storageClassName: <storageClass>.
   # If set to "-", storageClassName: "", which disables dynamic provisioning.
   # If empty or set to null, no storageClassName spec is
   # set, choosing the default provisioner (gp2 on AWS, standard on GKE, AWS, and OpenStack).
   storageClass: gp3
   # -- Selector for persistent disk
   selector: null
We’ve always had autoforget_unhealthy set to true because of dynamic IPs in our environment. Perhaps someone with more knowledge might be able to offer more insights. But I’d say if your IPs change, probably a good idea to enable autoforget_unhealthy.
