I have this error would you please someone help me check this
init compactor: failed to init delete store: googleapi: got HTTP response code 403 with body: <?xml version='1.0' encoding='UTF-8'?><Error><Code>UserProjectAccountProblem</Code><Message>The project to be billed is associated with a closed billing account.</Message><Details>The billing account for the owning project is disabled in state closed</Details></Error>
error initialising module: compactor
github.com/grafana/dskit/modules.(*Manager).initModule
/src/loki/vendor/github.com/grafana/dskit/modules/modules.go:138
github.com/grafana/dskit/modules.(*Manager).InitModuleServices
/src/loki/vendor/github.com/grafana/dskit/modules/modules.go:108
github.com/grafana/loki/v3/pkg/loki.(*Loki).Run
/src/loki/pkg/loki/loki.go:531
main.main
/src/loki/cmd/loki/main.go:129
runtime.main
/usr/local/go/src/runtime/proc.go:283
runtime.goexit
/usr/local/go/src/runtime/asm_amd64.s:1700
level=error ts=2025-06-06T17:21:51.832014487Z caller=log.go:223 msg="error running loki" err="init compactor: failed to init delete store: googleapi: got HTTP response code 403 with body: <?xml version='1.0' encoding='UTF-8'?><Error><Code>UserProjectAccountProblem</Code><Message>The project to be billed is associated with a closed billing account.</Message><Details>The billing account for the owning project is disabled in state closed</Details></Error>\nerror initialising module: compactor\ngithub.com/grafana/dskit/modules.(*Manager).initModule\n\t/src/loki/vendor/github.com/grafana/dskit/modules/modules.go:138\ngithub.com/grafana/dskit/modules.(*Manager).InitModuleServices\n\t/src/loki/vendor/github.com/grafana/dskit/modules/modules.go:108\ngithub.com/grafana/loki/v3/pkg/loki.(*Loki).Run\n\t/src/loki/pkg/loki/loki.go:531\nmain.main\n\t/src/loki/cmd/loki/main.go:129\nruntime.main\n\t/usr/local/go/src/runtime/proc.go:283\nruntime.goexit\n\t/usr/local/go/src/runtime/asm_amd64.s:1700"
