Loki Ruler Remote Evaluation implementation help
hello team,
we are running a big enough cluster to handle about >1TB of uncompressed data of logs and huge number of metrics.
we are using
LIDs - 0002 Remote Rule Evaluation
to perform rule execution. But it seems to be not stable and we are getting the following error.
│ loki-loki-distributed-ruler-749445c967-5t89k ts=2024-07-28T08:02:14.470716326Z caller=spanlogger.go:86 component=ruler evaluation_mode=remote user=platformpii method=ruler.remoteEvaluation.Query level=warn query_hash=1032185798 query="count_over_time ({container_name=\"pii-vault\"} |= \"latency\"[1m])" instant=2024-07-28T08:02:09.236487818Z response_time=1.797359754s msg="failed to evaluate rule" err="rpc error: code = ResourceExhausted desc = grpc: received message larger than max (8393682 vs. 4194304)"
we changed the grpc settings for ruler_client, query_scheduler.grpc_client_config, ingester_client.grpc_client_config, index_gateway_client.grpc_client_config, frontend_worker.grpc_client_config, frontend.grpc_client_config, to move the default from 4MB to 104 MB. But we are still getting this error.
following is our code sample without the major aspects. and critical info.
Can you please help us stabilize the our Grafana stack.
 ruler:
      enable_sharding: true
      query_stats_enabled: true
      evaluation_interval: 10s
      evaluation:
        max_jitter: 2s
        mode: remote
        query_frontend:
          address: "dns:///loki-loki-distributed-query-frontend-headless:9095"
      ruler_client:
        grpc_compression: snappy
        max_recv_msg_size: 104857600
        max_send_msg_size: 104857600
      wal:
        dir: ruler-wal
      wal_cleaner:
        period: 1h
      storage:
        type: s3
        s3:
          bucketnames: redacted
          endpoint: null
          region: region
          access_key_id: Redacted
          secret_access_key: redacted
      ring:
        kvstore:
          store: memberlist
      rule_path: /tmp/loki/scratch
      alertmanager_url: http://mimir-alertmanager:8080
      external_url: redacted
      remote_write:
        enabled: true
        clients:
          mimir:
            url: http://mimir-nginx/api/v1/push
  1. Did you change server grpc size as well?
  2. Have you consider aggregating your metrics a bit as well? I suspect you are not trying to send 8MB worth of message through your ruler.
Yes Server GRPC sizes are
grpc_server_max_recv_msg_size: 1048576000
grpc_server_max_send_msg_size: 1048576000
Aggregated metrics as in this is the count over time function that is being used for the same value… are you telling me the query is wrong, it seems that the data being queried is 8MB but i am hitting the 4MB limit somewhere in the chain of remote recording rule implementation.
