I’m trying to set up Loki with read/write separation, where one node (target: all ) can handle both read and write operations, and another node (target: read ) is read-only. However, I’m encountering an error when launching the read-only node.
I host on AWS EC2 and run in docker compsoe.
Current Setup
I have two nodes:
- Node 1 (172.31.87.229):
target: all- handles both read and write operations - Node 2 (172.31.87.205):
target: read- read-only node
Configuration Files
Node 1 (target: all) Configuration:
yaml
target: all
server:
http_listen_address: 0.0.0.0
http_listen_port: 3100
frontend:
compress_responses: true
log_queries_longer_than: 10s
memberlist:
join_members: ["172.31.87.229","172.31.87.205"]
dead_node_reclaim_time: 30s
gossip_to_dead_nodes_time: 15s
left_ingesters_timeout: 30s
bind_addr: ['0.0.0.0']
bind_port: 7946
gossip_interval: 2s
advertise_addr: "172.31.87.229"
schema_config:
configs:
store: tsdb
object_store: s3
schema: v13
index:
prefix: index_
period: 24h
common:
path_prefix: /loki
replication_factor: 1
compactor_address: http://172.31.87.229:3100
storage:
s3:
endpoint: minio:9000
insecure: true
bucketnames: loki-data
access_key_id: loki
secret_access_key: supersecret
s3forcepathstyle: true
ring:
kvstore:
store: memberlist
ruler:
storage:
s3:
bucketnames: loki-ruler
compactor:
working_directory: /tmp/compactor
Node 2 (target: read) Configuration:
target: read
server:
grpc_listen_port: 9096
memberlist:
join_members: ["172.31.87.229"]
bind_port: 7946
gossip_interval: 2s
advertise_addr: "172.31.87.205"
schema_config:
configs:
store: tsdb
object_store: s3
schema: v13
index:
prefix: index_
period: 24h
common:
path_prefix: /loki
storage:
s3:
endpoint: 172.31.87.229:9000
insecure: true
access_key_id: loki
ruler:
storage:
s3:
frontend_worker:
frontend_address: "172.31.87.229:9095"
grpc_client_config:
max_send_msg_size: 104857600
max_recv_msg_size: 104857600
frontend:
downstream_url: "http://172.31.87.229:3100"
compactor:
When launching the read-only node, I get this error:
read-1 | level=info ts=2025-04-01T15:33:07.831606109Z caller=worker.go:231 component=querier msg="adding connection" addr=172.31.87.229:9095
read-1 | level=info ts=2025-04-01T15:33:07.831938189Z caller=loki.go:545 msg="Loki started" startup_time=31.11932ms
read-1 | level=info ts=2025-04-01T15:33:07.838484306Z caller=memberlist_client.go:588 phase=startup msg="joining memberlist cluster succeeded" reached_nodes=1 elapsed_time=7.131725ms
read-1 | level=error ts=2025-04-01T15:33:07.839350039Z caller=frontend_processor.go:75 component=querier msg="error processing requests" address=172.31.87.229:9095 err="rpc error: code = Unimplemented desc = unknown service frontend.Frontend"
The error suggests that the frontend service is not available at the specified address. I suspect there might be an issue with my frontend configuration or the GRPC port settings.
Has anyone successfully set up Loki with read/write separation? What am I missing in my configuration? Any guidance would be greatly appreciated.
