Loki persistence configuration
How does loki store data ?
what is the configuration options ?
the example config seem to keep only 15 minutes :
ingester:
  lifecycler:
    address: 127.0.0.1
    ring:
      kvstore:
        store: inmemory
      replication_factor: 1
  chunk_idle_period: 15m
schema_config:
  configs:
    store: boltdb
    object_store: filesystem
    schema: v9
    index:
      prefix: index_
      period: 168h
storage_config:
  boltdb:
    directory: /loki/index
  filesystem:
    directory: /loki/chunks
how should it be changed to persist logs on disk over days…
thanks.
Any update on this?
(I have the same question regarding Loki data storage)
Sorry, no progress on this on my side, but tell us If you find out.
Any update on this?
