Loki Helm Chart retention isn't working
I’m trying to deploy a loki helm chart, using Argocd, in the loki helm configuration values I’m using the 24h log retention setting. I am using Ceph RBD as persistent storage.The Helm chart values in the configuration file located at /etc/loki/config/config.yml on the loki-0 pod appear to be applied correctly, but log retention isn’t taking effect. What could be the issue?
 source:
    repoURL: https://grafana.github.io/helm-charts
    chart: loki
    targetRevision: 5.30.0
    helm:
      releaseName: loki
      values: |
        limits_config:
            retention_period: 24h
        tableManager:
          retention_deletes_enabled: true
        compactor:
          retention_enabled: true
          shared_storage: filesystem
          working_directory: /var/loki/compactor
        loki:
          auth_enabled: false
          commonConfig:
            replication_factor: 1
          storage:
            type: filesystem
          limits_config:
        singleBinary:
          replicas: 1
        global:
          clusterDomain: cluster.local
          dnsNamespace: kube-system
          dnsService: rke2-coredns-rke2-coredns
Any updates on this?
I am struggling with the same issue. The only solution I found is to disable table manager and enable compactor, but this requires significant changes to the helm chart configuration…
