I have Reverse proxy (Loadbalancer Nginx) → 2 nodes: 1-st node for WRITE , 2-nd for READ and shared NFS storage.
Promtail (client) connects to Nginx, Nginx redirected to 1-st node (write)
I have configured Loadbalancer with round-robin with 2 nodes where each has write/read mode. The errors were the same.
Grafana-loki dashboard shows data but in the loki server logs we have 3 types of errors:
- msg=“failed to flush” err="failed to flush chunks: store put chunk: timeout, num_chunks: 1
- error checkpointing series" err="write /loki/wal/00000020: stale NFS file handle
- msg=“error syncing local boltdb files with storage” err=“failed to sync index set for table index_19822: timeout”
Node for WRITE:
loki[354091]: level=error ts=2024-04-09T13:08:12.689218272Z caller=checkpoint.go:613 msg=“error checkpointing series” err=“write /loki/wal/00000020: stale NFS file handle”
level=error ts=2024-04-09T12:59:52.980518058Z caller=flush.go:143 org_id=fake msg=“failed to flush” err=“failed to flush chunks: store put chunk: timeout, num_chunks: 1, labels: {filename="/var/log/zabbix/zabbix_server.log", host="zabbix-01.x.x", job="zabbix_server"}”
Node for READ:
level=error ts=2024-04-09T13:30:01.905551292Z caller=table_manager.go:133 index-store=boltdb-shipper-2020-10-24 msg=“error syncing local boltdb files with storage” err=“failed to sync index set for table index_19822: timeout”
Loki config:
NFS
auth_enabled: false
server:
http_listen_port: 3100
http_server_read_timeout: 60s # allow longer time span queries
http_server_write_timeout: 60s # allow longer time span queries
grpc_server_max_recv_msg_size: 33554432 # 32MiB (int bytes), default 4MB
grpc_server_max_send_msg_size: 33554432 # 32MiB (int bytes), default 4MB
log_level: info
querier:
max_concurrent: 16 #It is recommended to put about twice the number of CPUs. The default is 10
common:
path_prefix: /loki
replication_factor: 1
#storage:
filesystem:
chunks_directory: /loki/chunks
rules_directory: /loki/rules
memberlist:
join_members:
- grafana-loki-01.x.x:7946
- grafana-loki-02.x.x:7946
ingester:
lifecycler:
join_after: 10s
observe_period: 5s
ring:
replication_factor: 3
kvstore:
store: memberlist
final_sleep: 0s
chunk_idle_period: 1m
wal:
enabled: true
dir: /loki/wal
max_chunk_age: 1m
chunk_retain_period: 30s
chunk_encoding: snappy
chunk_target_size: 1.572864e+06
chunk_block_size: 262144
flush_op_timeout: 10s
schema_config:
configs:
store: boltdb-shipper
object_store: filesystem
schema: v11
index:
prefix: index_
period: 24h
storage_config:
boltdb_shipper:
shared_store: filesystem
active_index_directory: /loki/index
cache_location: /loki/boltdb-cache
filesystem:
limits_config:
enforce_metric_name: false
reject_old_samples: true
ingestion_rate_mb: 20
ingestion_burst_size_mb: 30
per_stream_rate_limit: 5MB # <string|int> | default = “3MB”
per_stream_rate_limit_burst: 15MB # <string|int> | default = “15MB”
query_range:
cache_results: true
results_cache:
cache:
enable_fifocache: true
fifocache:
max_size_items: 1024
validity: 24h
ruler:
alertmanager_url: http://localhost:9093
ingester_client:
grpc_client_config:
# The maximum size in bytes the client can send.
# CLI flag: -.grpc-max-send-msg-size
max_send_msg_size: 33554432 # 32mb, default = 16777216]
query_scheduler:
max_outstanding_requests_per_tenant: 2048
grpc_client_config:
