Hello everyone,
I’ve been driven mad for a week now with an issue related to the Loki driver for Docker.
I’ve followed the simple installation documentation. However, my Docker system logs never seem to make it to Loki. Interestingly, my application logs are successfully sent via Promtail.
The Loki server is definitely reachable from the containers.
The logs no longer show up when using docker logs, which seems to confirm that they are indeed being sent somewhere.
If anyone has any ideas
, I’ve scoured the internet and consulted ChatGPT to no avail.
I am using Docker Desktop for Mac ARM.
docker version
> Client:
Version: 24.0.7
API version: 1.43
Go version: go1.20.10
Git commit: afdd53b
Built: Thu Oct 26 09:04:20 2023
OS/Arch: darwin/arm64
Context: orbstack
> Server: Docker Engine - Community
Engine:
Version: 24.0.7
API version: 1.43 (minimum version 1.12)
Git commit: 311b9ff
Built: Thu Oct 26 09:08:17 2023
OS/Arch: linux/arm64
Experimental: false
containerd:
Version: v1.7.7
GitCommit: 8c087663b0233f6e6e2f4515cee61d49f14746a8
runc:
Version: 1.1.9
GitCommit: 82f18fe0e44a59034f3e1f45e475fa5636e539aa
docker-init:
Version: 0.19.0
GitCommit: de40ad0
loki-docker-driver:2.9.4
> docker plugin list
ID NAME DESCRIPTION ENABLED
c5b1f4293b46 loki:latest Loki Logging Driver true
The configuration added under my containers in the docker-compose.
yamlCopy code
> logging:
driver: loki
options:
loki-url: "http://loki:3100/loki/api/v1/push"
loki-external-labels: job=php74_logs,environment=production
Conf loki
auth_enabled: false
server:
http_listen_port: 3100
common:
path_prefix: /tmp/loki
storage:
filesystem:
chunks_directory: /tmp/loki/chunks
rules_directory: /tmp/loki/rules
replication_factor: 1
ring:
instance_addr: 127.0.0.1
kvstore:
store: inmemory
schema_config:
configs:
store: boltdb-shipper
object_store: filesystem
schema: v12
index:
prefix: loki_index_
period: 24h
