Using the metric sum by (reason) (rate(loki_ingester_chunks_flushed_total[1h])) I can see, that almost all chunks get flushed for reason “idle”. For testing purposes I set max_chunk_age: 5h and chunk_idle_period: 6h in the ingester config.
From my understanding the reason for chunks being flushed should never be “idle”, because the limit of max_chunk_age should be hit first. Looking at the metric from above it still shows most chunks being flushed for reason “idle”, even after a day.
Can anybody explain why this is the case?
I’m using Loki Version 3.3.2 installed via loki helm chart 6.25.0
I’ve never tried this before, so I am not sure. Can you hit the /config endpoint on your ingester and post the results here, please?
ingester_client:
pool_config:
client_cleanup_period: 15s
health_check_ingesters: true
remote_timeout: 1s
remote_timeout: 5s
grpc_client_config:
max_recv_msg_size: 104857600
max_send_msg_size: 104857600
grpc_compression: ""
rate_limit: 0
rate_limit_burst: 0
backoff_on_ratelimits: false
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
initial_stream_window_size: 63KiB1023B
initial_connection_window_size: 63KiB1023B
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_insecure_skip_verify: false
tls_cipher_suites: ""
tls_min_version: ""
connect_timeout: 5s
connect_backoff_base_delay: 1s
connect_backoff_max_delay: 5s
ingester:
lifecycler:
ring:
kvstore:
store: memberlist
prefix: collectors/
consul:
host: localhost:8500
acl_token: ""
http_client_timeout: 20s
consistent_reads: false
watch_rate_limit: 1
watch_burst_size: 1
cas_retry_delay: 1s
etcd:
endpoints: []
dial_timeout: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
username: ""
password: ""
multi:
primary: ""
secondary: ""
mirror_enabled: false
mirror_timeout: 2s
heartbeat_timeout: 1m0s
replication_factor: 1
zone_awareness_enabled: false
excluded_zones: ""
num_tokens: 128
heartbeat_period: 5s
observe_period: 0s
join_after: 0s
min_ready_duration: 15s
interface_names:
- eth0
- lo
enable_inet6: false
final_sleep: 0s
tokens_file_path: ""
availability_zone: ""
unregister_on_shutdown: true
readiness_check_ring_health: true
address: ""
port: 0
concurrent_flushes: 32
flush_check_period: 30s
flush_op_backoff:
min_period: 10s
max_period: 1m0s
max_retries: 10
flush_op_timeout: 10m0s
chunk_retain_period: 0s
chunk_idle_period: 6h0m0s
chunk_block_size: 262144
chunk_target_size: 1572864
chunk_encoding: snappy
max_chunk_age: 5h0m0s
autoforget_unhealthy: false
sync_period: 1h0m0s
sync_min_utilization: 0.1
max_returned_stream_errors: 10
query_store_max_look_back_period: 5h41m0s
wal:
enabled: true
dir: /var/loki/wal
checkpoint_duration: 5m0s
flush_on_shutdown: false
replay_memory_ceiling: 4GB
index_shards: 32
max_dropped_streams: 10
shutdown_marker_path: /var/loki
owned_streams_check_interval: 30s
kafka_ingestion:
enabled: false
partition_ring:
kvstore:
store: memberlist
prefix: collectors/
consul:
acl_token: ""
watch_rate_limit: 1
watch_burst_size: 1
cas_retry_delay: 1s
etcd:
endpoints: []
dial_timeout: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
username: ""
password: ""
multi:
primary: ""
secondary: ""
mirror_timeout: 2s
min_partition_owners_count: 1
min_partition_owners_duration: 10s
delete_inactive_partition_after: 13h0m0s
system
Closed
February 6, 2026, 7:49am
4
